Sticky pressure switch
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Fishguy, Dec 23, 2008.
  1. Fishguy
    Fishguy New Member
    May 29, 2008
    I have recntly installed a new pressure switch. I also was finally able to check the pressure tank and adjust the switch to it's proper setting(see previous thread). Now, every couple of days, I wake up to no water. (I have a KDF filter that self flushes over nite) I have to go outside (burr) and just lightly tap on the new switch and the pump kicks in. All will be fine for a couple more days.
    Any idea as to the problem?
    Thanks in advance,
    Steve
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Did you buy a quality switch or a big box switch?
    Did you clean or at least check the pipes feeding pressure to the switch to see if they were clear?
    bob...
  4. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    That's gotta be it
  5. Fishguy
    Fishguy New Member
    May 29, 2008
    pressure switch
    The line to the switch was clear and yes it's a switch from Lowe's.
    Steve
  6. WV Hillbilly
    WV Hillbilly New Member
    Aug 1, 2008
    WV
    I assume you didn't have this problem till you installed the new switch . If you're sure the water pressure line feeding the switch is clear I'd say you got a defective switch .
  7. Fishguy
    Fishguy New Member
    May 29, 2008
    Who Me??
    I am in NO WAY surprised by that!!
    Steve
  8. speedbump
    Jul 15, 2005
    Riverview, Fl.
    That makes three of us.
    bob...
  9. sammyhydro11
    sammyhydro11 Previous member
    Dec 20, 2006
    Well Drilling-Test Borings-Water Treatment-Well an
    Massachusetts
    Pressure switches from lowes are complete garbage. I have replaced 3 of them in the last 2 months. You need to go to a plumbers supply store and get yourself a good quality square D switch.
    sammy
    www.tylerwellandpump.com
Similar Threads: Sticky pressure
Pumps and Tanks Well Forum & Blog. Water is life. Question about sticky "Submersible Pumps and multiple check valves?" Mar 27, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Sticky laundry pump May 30, 2008
Pumps and Tanks Well Forum & Blog. Water is life. "sticky" check valve Mar 22, 2005
Pumps and Tanks Well Forum & Blog. Water is life. Well Pressure question Mar 14, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Well Pump Pressure Switch constantly cycling on and off Mar 9, 2017
