Sterling shower panel with crack
jks84
New York
I am installing a sterling 4 piece shower set. I am about to install the back wall. When I opened the package I noticed that the bottom of the panel, where it meets the pan, has two cracks. These cracks don't wrap around to the front side of the panel. They are just on the bottom. Should I return it? Epoxy it, leave it? I attached some pictures for reference. Thank you. - Jake
Master Plumber Mark
www.weilhammerplumbing.com
Usually when I install one of these I will use some White Siliconeized Alex Dap
and put a good bead of the stuff along the bottom where
this sits on... I normally lay it on pretty thick and set the top down into it...
then wipe off the excess with a wet towel...
one of the reasons I do this is to keep water from finding a way along that back wall
and down the sides .. The Alex dap works well. and I also throw a large bead up both
walls where the snap together........
Cacher_Chick
Test, Don't Guess!
There are big problems in shipping these units without them becoming damaged. You paid for an unbroken product, it is certainly within reason to expect one.
JRC3
S.W. Ohio
Yep.
Return it. Inspect the new box thoroughly for the smallest of contact from anything. Check the corners of the box for crumpling or drag marks. Open suspect areas and check for damage before you even leave with it.
Another option is to call the maker and see if they want to just send you that one piece. Look over the instructions, and you will get an idea if the maker would like to be contacted for such things or not.
jks84
New York
I ended up getting some epoxy and putting it on the backside of both cracks since neither one had wrapped around the front of the panel. There wasn't any movement around the crack before and now the epoxy has filled it in and stiffened it up so I don't see the crack spreading to where water could leak in.
