Sterling faucet need for tub, A0980 handle
mperry34
Chino, CA
I have been looking everywhere for a replacement faucet made by Sterling. The home was built in 1984 and I have been told that this is the only one I can use. Please help.
Thank you,
What do you want to replace? The whole thing? The cartridge? The handle?
Unless you have access from the rear or are willing to make the hole bigger from the front (they make special decorative plates to cover that larger hole), you generally don't have enough room to replace the whole valve - only service what you have. If you are willing to replace the whole thing, then the sky is the limit, you can use almost anything. What was your plan or desire?
mperry34
Chino, CA
Sterling Faucet
Just the handle (the picture shown) The valve is fine. Thank you,
I usually throw] the handles away when I replace that valve, but a good parts store may be able to help you. The handle is Sterling part #A0980. Faucets Plus lists it but they show a square stem instead of the "T" which you probably have.
