diggity
So I'm trying to install a Stenner pump for soda ash injection and I'm confused about the wiring. I understand that it's supposed to be wired in to the pressure switch somehow, but I'm not sure how. (Frankly, I was under the impression that it would have a relay circuit, so that the pressure switch would trigger it, but not power it per se. But apparently that's not the way it works, as the pump only has one wire, and that is the 110 volt plug). So how do I wire this thing in? Do I have to cut the plug off the power cord? And then how do I attach it to the pressure switch? And did I order the wrong model? The one I have is for 110 volt, but I think my well is probably on a 220 circuit, right? Should I have gotten the 220 volt model instead? Sorry for all the questions - I'm totally unsure how to proceed. Any assistance is appreciated - thanks in advance!
