steel pipe problem
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by kiltybob, Apr 19, 2013.
  1. kiltybob
    kiltybob New Member
    Apr 19, 2013
    milwaukee wi
    I can't get steel piping off. The pipe was clogged, and deteriorated on one end, and alot of the threading came off. I used WD-40, and then a pipe wrench, but it wouldn't budge. This is located under a kitchen sink with little room to move.
  2. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    Are you talking about a drain line or the water supplies?
  4. Terry
    Aug 17, 2004
    If you are trying to remove a pipe nipple for the shutoff, it's going to take some muscle.
    A pipe wrench helps to break it loose, though sometimes if the pipe is crushing, you may need an easy out.
  5. hj
    I assume it is the drain line, and if so, you need the biggest wrench you can fit inside the cabinet and the heaviest hammer you can swing under there to "beat" on the wrench.
Similar Threads: steel pipe
Plumbing Forum, Professional & DIY Advice Leaking galvanized steel pipe in basement Aug 3, 2016
Plumbing Forum, Professional & DIY Advice Is electrolysis a issue with copper pipe and steel fasteners? Mar 1, 2016
Plumbing Forum, Professional & DIY Advice Rusted galvanized steel threads on hot/cold water pipes... Feb 20, 2015
Plumbing Forum, Professional & DIY Advice How can I fix this Galvanized steel Pipe Thread in my shower? Mar 24, 2012
Plumbing Forum, Professional & DIY Advice rerouting 2" galvanized steel vent pipe Dec 1, 2011
