Steel of Acrylic Tub
Discussion in 'Shower & Bathtub Forum & Blog' started by JEP, Nov 20, 2005.
  1. JEP
    JEP New Member
    Nov 11, 2005
    Ringwood, NJ
    I will be replacing the current steel bathtub in my bathroom. Cast iron is not an option for a few reasons cost etc. My choices are Steel or Acrylic. Is one better than the other? What are the pros and cons?
    I know both should be bedded in mortar. What kind of mortar is the best to use?
    Thanks John
  2. hj
    tubs
    The only two advantages to steel are that it is cheap and it is light, so it can be carried easier. I am not very fond of acrylic either, but if those are the only two choices you have, then it is the only one you should use.
  4. JEP
    JEP New Member
    Nov 11, 2005
    Ringwood, NJ
    Thanks hj
    Excluding cast iron, are there other choices I'm missing that I should be considering?
    Thanks John
  5. JEP
    JEP New Member
    Nov 11, 2005
    Ringwood, NJ
  6. JEP
    JEP New Member
    Nov 11, 2005
    Ringwood, NJ
  7. sulconst2
    sulconst2 New Member
    Jul 11, 2005
    remodeler
    old bridge nj
    316 lbs for the kohler. thats a hump up the stairs. hard enough taking one down. american standard makes an americast tub. solid and lighter. good thing about acrylic, besides being light, is the color goes all the way thru. as long as the tub is installed correctly you would be ok. would not recommend the lasco for your own home. maybe a job were customer wants the something for nothing!
  8. JEP
    JEP New Member
    Nov 11, 2005
    Ringwood, NJ
    I know getting the Kohler cast iron tub up the stairs and in place will not be easy, but I'm thinking that down the road I won't be saying I should have. :)
    It seems some folks here are not crazy about acrylic and steel tubs.
  9. plumbernj
    plumbernj In the Trades
    Aug 14, 2005
    New Jersey
    Get an Americast
    This is easy... get an Americast tub. Home Depot sells them.
Similar Threads: Steel Acrylic
Shower & Bathtub Forum & Blog Acrylic vs Enameled Steel bathtub Mar 3, 2013
Shower & Bathtub Forum & Blog Steel, styrene, fiberglass or acrylic ... which is best for replacement tub? Nov 5, 2007
Shower & Bathtub Forum & Blog Enameled steel tub rusted flange Sep 16, 2015
Shower & Bathtub Forum & Blog cracking porcelain over steel tub Feb 13, 2014
Shower & Bathtub Forum & Blog Easiest to Keep Clean Faucet Finnish: Chrome or Brushed Nickel/Stainless Steel Oct 16, 2013
