steam generator drain
Discussion in 'Shower & Bathtub Forum & Blog' started by kirkm, Sep 21, 2004.
  1. kirkm
    kirkm New Member
    Sep 4, 2004
    I am roughing in a stream room/shower with a steam generator in a near-by storage area that has a auto flush to washout the system after use. The instructions say to make sure connect the drain out and pressure relief follow all applicable codes with no guidance :confused:. 1.5" Drain is readily accessible below where I plan to mount the steam unit. Can I connect these directly to the drain using a trap or do I need some kind of air gap device?
    Kirk
  2. e-plumber
    e-plumber DIY Senior Member
    Sep 1, 2004
    New York
    Steam Gererator
    [​IMG] The picture does not show it but usually a floor drain or an indirect drain connection is provided for the steam unit to handle the relief valve discharge if it were to open. A local licensed plumber can advise you or at least call the Building Department to find out what is required.
  4. hj
    drain
    You still need a trap on the sanitary drain opening, but the steamer's drain has to have an air gap between it and the floor drain.
  5. kirkm
    kirkm New Member
    Sep 4, 2004
    Thanks. I will call the county inspector as I am planning to do the installation. The drain available in a sanitary drain and I would want to discharge into it and could install a p trap. I am a little concerned that the steam generator would get infrequent use and the trap could dry out with an air gap. I have a floor drain that goes to sump pump crock where ac condensation line is running but it is know where near where I plan to install the steam generator.
Similar Threads: steam generator
Shower & Bathtub Forum & Blog Steam Shower Generator Installation Nov 22, 2016
Shower & Bathtub Forum & Blog is it safe to install steam generator that is over recommended power size? Dec 9, 2013
Shower & Bathtub Forum & Blog Plumbing Advice for steam generator drain Jun 21, 2013
Shower & Bathtub Forum & Blog Wiring for steam generator control Mar 6, 2011
Shower & Bathtub Forum & Blog Steam shower - steam generator recommendations Jan 23, 2011
