steam boiler radiator return pipe
Discussion in 'Boiler Forum' started by rcdba, Jan 10, 2013.
  1. rcdba
    rcdba New Member
    Jan 7, 2013
    Brooklyn, NY
    I have a steam boiler radiator system. The return line of threaded black pipe in the basement is corroding. I've already spotted a leak. I replaced the part with a new piece and it was full of water. Because I would like to finish the basement, the return piping needs to be replaced. It's quite an investment. Currently, parts of the piping is laying on top of concrete and partially embedded in concrete. It only lasted for 25 years. The current pipe is 1-1/4 diameter.
    Is there another material I can use to replace the return pipe. Something better than black pipe. Stainless steel, Cooper ? If so, what grade?
    To last longer, I would like to bury (not embed) the pipe under the concrete slab with a waterproof wrapping and surrounded with a gravel bed to keep it dry. Is this possible ?
    Also, is it normal to have water in these pipes ? I had to close the water valve to the boiler and drain it? It does have a Hartford Loop.
    thanks for looking
    Richard
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    With a Hartford Loop that line will hold water. The reason for the loop is to protect the boiler from loosing all of it's water should a leak in the return line happen.
    John
  4. rcdba
    rcdba New Member
    Jan 7, 2013
    Brooklyn, NY
    that makes sense.. Thank you, John
Similar Threads: steam boiler
Boiler Forum Steam Boiler Control Mar 17, 2016
Boiler Forum Is it time for a new steam boiler? Jan 3, 2016
Boiler Forum Steam Boiler Water Removal (Advice) Feb 25, 2015
Boiler Forum Steam Boiler auto fill valve and low water cutoff Jan 16, 2015
Boiler Forum Hot Water Lopp off Steam Boiler Suggestions Nov 20, 2013
