Squealing Moen Tub Spout or Shower Valve
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by davidhmd, Mar 22, 2011.
  1. davidhmd
    davidhmd New Member
    Mar 28, 2007
    Maryland
    Recently installed new Moen POSI-TEMP (2570) Tub/Shower Valve, and Moen Brantford style tub spout.
    From day 1, there has been a very loud squeal/whistle when you turn on the water to the tub.
    At first I thought it was the valve, and I haven't closed up the walls yet, but now I'm relatively sure, the sound is coming from the tub spout.
    Can I correct the problem myself, or do I need to choose a different style spout?
    Installation details. All new copper plumbing, shower valve, valve trim, and tub spout, reused previous hand-held shower head. Shower head never whistled before, so confident that's not the problem.
    It doesn't squeal if you engage the shower diverter before you turn on the water and if you didn't pre-engage it, it stops squealing as soon as you do engage it.
    Tub spout slides over pipe and is held in place by clamp tightened with allen wrench.
    Thank you in advance for your help.
  2. worsnup
    worsnup plumbing contractor
    Jun 7, 2010
    plumbing contractor
    phoenix az
    i would check the water pressure
  4. jimbo
    jimbo Plumber
    Fiddle with some other faucets to see if you can duplicate the squeal..it could be from elsewhere, like the pressure regulator.
  5. davidhmd
    davidhmd New Member
    Mar 28, 2007
    Maryland
    Squeal only occurs with tub spout. All other sink faucets and toilets are normal.
    Tub doesn't squeal if you engage the shower diverter before turning on the water.
    If the pressure regular is that big WATTs cylinder near my water heater, can you explain how to properly set the pressure? I installed it. I still have the instructions and I know the inlets and outlets are hooked up correctly, but I never really understood how to set the pressure.
  6. jadnashua
    That could be a PRV, or something else. If it has a bolt out one end with a nut locking it in position, that's probably a PRV. Before you adjust anything, get a screw-in pressure gauge - attach it to say the WH, a hose bib, or washing machine and check the pressure. If it is a prv, and needs to be adjusted, you loosen the nut and turn the bolt in or out to raise or lower the pressure. When they get worn out, the pressure can rise rather than being stable (as it can if you don't have an expansion tank, if you have a PRV, or it is bad, too).
    Some diverter tub spouts just aren't the best and can make that squeal, but it usually takes awhile for the seal to wear before it happens. High pressure can do weird things, though.
  7. 2507FJ
    2507FJ New Member
    Apr 20, 2011
    self employed
    Georgetown, TX
    I was looking for a post about valve wrench and found this one. It wasn't what I was looking for but good info anyway.
    Cheers.
Similar Threads: Squealing Moen
Plumbing Forum, Professional & DIY Advice Squealing / hissing sound from tub faucet Jun 13, 2016
Plumbing Forum, Professional & DIY Advice Squealing water line Feb 12, 2015
Plumbing Forum, Professional & DIY Advice Squealing PRV - Any ideas? Jun 22, 2008
Plumbing Forum, Professional & DIY Advice Squealing shower Apr 1, 2008
Plumbing Forum, Professional & DIY Advice Squealing in pipes after installing water hammer arrestors Nov 29, 2007
