square drain help
Discussion in 'Shower & Bathtub Forum & Blog' started by striker, Mar 18, 2009.
  1. striker
    striker New Member
    Mar 18, 2009
    Hi all,
    I'm redoing my shower and would like to put in a square drain. I've found one at lowe's, but the clamping ring has 4 holes, whereas my current one has only 3, and I'd like to avoid ripping out the whole drain. Any ideas where I can find a square drain with a 3 hole clamping ring? I have a lowes, ace, home depot, and fergusons around here, with a few places, but I'm not opposed to online.
    Thanks for your help. Let me know if I'm not using the right terminology. I think my 3 hole clamping ring had a different size so I couldn't just swap parts iwth the new square drain with 4 hole clamping ring.
  2. jimbo
    jimbo Plumber
    Sounds like you are trying to mix-and-match. That never works.
  4. hj
    drain
    Even if you found one, there is no guarantee the bolt pattern would be the same. There are NO standards so each company makes its own design.
Similar Threads: square drain
Shower & Bathtub Forum & Blog EBBE Square drain adapter kit for Insta-Set cast iron drain, for hot mopping? Mar 24, 2012
Shower & Bathtub Forum & Blog Square strainer for no caulk shower drain Apr 17, 2009
Shower & Bathtub Forum & Blog Square Shower Drain Jun 16, 2005
Shower & Bathtub Forum & Blog square trim shower drain Jan 23, 2005
Shower & Bathtub Forum & Blog Can I get a 1 piece 32 inch square shower Dec 29, 2016
