square D Pupmtrol 20/40 Pressure Switch
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by daveatthelake, Jun 19, 2006.
  1. daveatthelake
    daveatthelake New Member
    Dec 20, 2005
    Can someone tell me exactly how to adjust this switch? I have not been able to find a manual online for this product. I have to adjust it due to the idiot who maintaned our camp before we bought it adjusted the heck out of BOTH SCREWS to compensate for the air bladder in the tank that failed. BTW this doesnt solve anything....
    So all said and done we have a new pressure tank and i have the air bladder pressure set to 18 lbs. I am not able to adjust it so i can get 20/40 out of it. I can get the 40 cut out but the 20 is eluding me.......
    I understand that one screw adjusts the range up and down together and the other the spread between the ranges.
    How do I do this?
    Does the little screw adjust the spread? If so by tightening it does the differential increase or decrease? Am I even close? lol
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    The tall spring (assuming you have a Square D Switch) adjusts both on and off pressures. So the first setting you want to achieve is the 20/on pressure with the tall spring. When you have that working, use the short spring to adjust the off pressure of 40 psi.
    bob...
  4. daveatthelake
    Dec 20, 2005
    I do have the square d 20/40 switch.
    so i had it backwards....do you remember how the spread works with the small screw? Lets say my on is adjusted properly to 20psi but it shuts off at 36psi instead of 40, do i tighten or loosen the small screw?
    Your help is much appreciated thank you.
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Turn it clockwise to raise the pressure. The short one will only effect the off pressure.
    bob...
  6. daveatthelake
    Dec 20, 2005
    bob thank you!!
Similar Threads: square Pupmtrol
Pumps and Tanks Well Forum & Blog. Water is life. Old Square D Pressure Switch with built in light Jul 30, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Square D pressure switch 40/60 trobleshooting Oct 23, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Square D pressure switch 9013FSG 2 Jun 3, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Identify this square mass in old ejector pit Mar 23, 2014
Pumps and Tanks Well Forum & Blog. Water is life. New Square D pressure switch, was perfect 40-60 now 40-52 and unable to raise cut off Nov 6, 2013
