Sprinklers Not Shutting Off
Discussion in 'Irrigation / Sprinkler Forum' started by AZ1JoeT, Apr 13, 2007.
  1. AZ1JoeT
    AZ1JoeT New Member
    Mar 18, 2007
    I have a four zone sprinkler system. Zone 1 does not shut off. It also sounds as if water is running at the control box in the ground while none of the sprinklers are on.
    When zone 1 continues running I am unable to shut it off at the timer unless I start a "Test" and then stop the test while those sprinklers (zone 1) are running.
    What can cause sprinklers to keep running? Only 10 or 12 things? :)\
    Much appreciation.
    JT
  2. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    No more than eleven. Look at the valves in the outdoor valve box. Make sure that one of them is not manually set open. (play the Sesame Street game - "One of these things is not like the other")
  4. AZ1JoeT
    AZ1JoeT New Member
    Mar 18, 2007
    If by valves, you mean the little switches I can manually open or close to turn a specific zone on or off, then they all appear to be closed (off).
    Thanks for the reply.
    JT
  5. Wet_Boots
    Mar 23, 2007
    Metro NYC
    Valves. They're the devices that physically control the water. Confirm that none of them are manually set to stay open.
Similar Threads: Sprinklers Shutting
Irrigation / Sprinkler Forum How to know which zone on valve goes to which sprinklers Feb 19, 2017
Irrigation / Sprinkler Forum Low Pressure Issue - sprinklers/well May 7, 2016
Irrigation / Sprinkler Forum Motion Beam for Sprinklers Apr 24, 2016
Irrigation / Sprinkler Forum Leaking sprinklers when system is off Feb 19, 2014
Irrigation / Sprinkler Forum pump start relay bad? (hunter sprinklers) Oct 4, 2011
