Sprinkler zone turns on automatically
Discussion in 'Irrigation / Sprinkler Forum' started by nate.barclay, Apr 10, 2010.
  1. nate.barclay
    nate.barclay New Member
    May 25, 2007
    Hello all. I just turned on my water today to my sprinkler system to be met with an odd surprise. As soon as I turn the valve from the back flow assembly to the sprinkler line, one of my zones fires up and I have no way of controlling it other than to turn the valve back off. I can flip my sensor switch on the wall unit to bypass and test the other zones, but I can't get this one zone to shut off. Any ideas? Thanks.
    Nate
  2. Fireguy97
    Fireguy97 Irrigation Contractor
    Mar 21, 2010
    Irrigation Contractor / Certified Backflow Assembl
    Kamloops, in Beautiful British Col
    You could have either a bad solinoid, a stuck solinoid, or whoever winterized your system open the valves manually (by turning the solinoid) and left that one open.
    Mick
  4. hj
    Most valves WILL operate when the water is first turned on because they have lost their pressurization, but they turn off as soon as the valve chamber fills with water. You either have a damaged diaphragm, bad solenoid valve, or the manual control is turned on.
Similar Threads: Sprinkler zone
Irrigation / Sprinkler Forum How to know which zone on valve goes to which sprinklers Sunday at 3:14 PM
Irrigation / Sprinkler Forum Faulty "handoff" between sprinkler zones Nov 7, 2014
Irrigation / Sprinkler Forum Sprinkler zone not working Oct 21, 2011
Irrigation / Sprinkler Forum toro Sprinkler system stuck in zone 2 Jul 26, 2011
Irrigation / Sprinkler Forum Sprinkler stuck in Zone 1. Won't turn off. Jul 24, 2011
