Sprinkler zone not working
Discussion in 'Irrigation / Sprinkler Forum' started by Longhorn21, Oct 21, 2011.
  1. Longhorn21
    Longhorn21 New Member
    Oct 21, 2011
    Austin, TX
    I have a hunter sprinkler system and my zone 4 isn't working. I've put my multimeter on the com wire
    and on my timer wire at the control box and I'm getting 24-25 volts. Then I go to the valves and put the multimeter on the wires at the valve solenoid and I get 24-25 volts, now when I hook all the wires up to the solenoid the volts drop to 0. I don't understand, I get power at the control box, so the wires under
    ground get power at the valves, but when I hook them all up no power. Please somebody help this is
    driving me nuts!!!!!
  2. mike1059
    mike1059 irrigation tech.
    Jun 6, 2011
    irrigation tech. for a landscape company
    Portland, OR
    as a test you can switch solenoids with another valve to see if your problem moves to the new valve. that said, in my experiance what youve said tells me that the solenoid is bad and needs to be replaced.
Similar Threads: Sprinkler zone
Irrigation / Sprinkler Forum How to know which zone on valve goes to which sprinklers Sunday at 3:14 PM
Irrigation / Sprinkler Forum Faulty "handoff" between sprinkler zones Nov 7, 2014
Irrigation / Sprinkler Forum toro Sprinkler system stuck in zone 2 Jul 26, 2011
Irrigation / Sprinkler Forum Sprinkler stuck in Zone 1. Won't turn off. Jul 24, 2011
Irrigation / Sprinkler Forum New sprinkler timer suddenly won't switch to 2nd zone manually May 22, 2011
