Sprinkler valve mystery
Discussion in 'Irrigation / Sprinkler Forum' started by zendog13, May 27, 2009.
  1. zendog13
    zendog13 New Member
    May 27, 2009
    Okay, here goes.
    Five years ago bought a house w/ a 3-zone Richdel system. The analog controller is so old I think it was once used by Moses.
    We turned the system off when we bought the place and waited until we could turn our attention to the back yard landscaping (after 5 years of interior refurb...another story).
    In first attempts to re-start, 2 of the three zones are fine.
    The third is not working. I don't have a tester, but I rigged a cheap-o activator w/ 3 9-volt batteries. Nothing. Just a kind of rushing sound, like water through a nozzle. (Not really an electrical "buzz" as I've heard described.) But no water from the sprinklers.
    I did notice that two of the pop-up heads in that zone were leaking a small bit, and I unscrewed the collar a bit to see that there was at least some water pressure. I cleaned and reassembled that head. Still nothing but a tiny leak.
    I even swapped the wiring from another valve. Nada. I even changed the solenoid. Still nothing. Just the rushing sound.
    Any ideas? Should I try cleaning the valve? Should I just save the time and replace it? While I'm at it, should I chuck this antique controller?
    Also, in another zone using a low-pressure above ground line, I swapped out two spray heads and put in two drip lines which are not dripping. As I'm thinking about it, you probably can't put drip lines on the same hose as sprayers...:D Am I right?
    Thanks y'all.
  2. Andrew P.
    Andrew P. Electrical Engineer
    Dec 29, 2006
    Near San Jose, California
    You won't hear a buzzing sound from the solenoid when you power it from three 9-volt batteries in series. The buzzing only occurs when the solenoid is powered from AC, provided by the transformer in the valve controller. However, if you're next to the valve when you apply 27 VDC, you should hear a "click" as the solenoid pulls in. You may want to check the voltage of your batteries under load, to make sure that they're providing 26-27 volts initially and at least 18 volts continuously after the solenoid has been energized. If the batteries are fresh, this shouldn't be a problem. If you have an AC voltmeter handy, check the voltage at the solenoid while it is being operated by the controller. The controller should produce at least 24 VAC "open circuit" and at least 18 VAC continuous under load at the solenoid.
  4. zendog13
    zendog13 New Member
    May 27, 2009
    Yeah, but...
    Thanks for the suggestion re: the volt meter. I've been waiting for an excuse to buy one.
    HOWEVER, your suggestion doesn't take into account the fact that I changed the wiring to use the power from a working valve/zone and still had the same results - nothing. Which (especially since I'd changed the solenoid) leads me to believe that the problem must be somewhere in the valve itself.
    Anybody else? Anybody got a comment on the "whooshing" noise?
  5. tomm
    tomm New Member
    Feb 21, 2008
    Check the diaphragm INSIDE the valve
  6. hj
    valve
    If the diaphragm has a hole or tear in it, or is jammed so it cannot lift, the valve will not operate.
  7. zendog13
    zendog13 New Member
    May 27, 2009
    Valve cleaned - still sounds like Niagra Falls
    I pulled the valve apart yesterday and everything seemed fine. No tears. Not much gunk either.
    I ran the water and flushed the line. Cleaned and reassembled the valve.
    Started it back up and I've got the same thing. Dribbling from the pop-up heads.
    At this point, logic is telling me that I've got a break in the line. Still, after hours of running it, I can't find a swamp.
    But the real mystery to me is the noise that's coming from the valve. Very loud sound of water rushing through. None of the others sound like this, so it reasons that the noise has something to do with the problem. I don't understand how a break further down the line would cause that noise at the valve.
  8. upper
    upper DIY Senior Member
    May 30, 2009
    Fresno, CA
    sprinkler valve
    Cut the outlet side of the valve,turn it on,check flow.No flow,replace valve.Good flow ,broken pipe.Easy deal Upper also check the flow control
Similar Threads: Sprinkler valve
Irrigation / Sprinkler Forum How to know which zone on valve goes to which sprinklers Feb 19, 2017
Irrigation / Sprinkler Forum automatic sprinkler valves May 1, 2013
Irrigation / Sprinkler Forum Installing sprinkler shut off valve below frostline Apr 17, 2012
Irrigation / Sprinkler Forum is it normal for water sprouting out from the sprinkler valve vent Jun 11, 2011
Irrigation / Sprinkler Forum 1" Male Threaded In-line Jar-Top Sprinkler Control Valve not working right help Aug 14, 2010
