sprinkler timer cycling
Discussion in 'Irrigation / Sprinkler Forum' started by gooseloony, May 15, 2011.
  1. gooseloony
    gooseloony New Member
    May 15, 2011
    el barrio, CA
    I replaced a sprinkler timer recently (Orbitz) and now my sprinklers keep cycling through and won't shut off until I maually shut them off. Any ideas as to the problem? Thanks in advance
  2. hj
    Either it is defective or is programmed improperly. NOTHING we can do to diagnose it without being there.
  4. Cookie
    Cookie .
    Oct 7, 2005
    Try doing this there might be overlapping start times programmed. Clear all start times and then enter only one start time. If you would like to water more than once a day, enter the next start time for later in the day. A start time is the initial time of day when the timer will begin to water. Each station or zone will then water in sequence according to its chosen duration. Multiple start times allow you to water all stations more than once in the same watering day.
Similar Threads: sprinkler timer
Irrigation / Sprinkler Forum How to change timer on sprinkler system Jun 25, 2012
Irrigation / Sprinkler Forum New sprinkler timer suddenly won't switch to 2nd zone manually May 22, 2011
Irrigation / Sprinkler Forum Toro Greenkeeper sprinkler timer PCB resistor problem Apr 6, 2010
Irrigation / Sprinkler Forum toro lawnmaster sprinkler timer Jun 10, 2009
Irrigation / Sprinkler Forum Sprinkler Timer Aug 9, 2008
