Sprinkler system with Spherical holding tank
Discussion in 'Irrigation / Sprinkler Forum' started by Mike19, Jun 27, 2008.
  1. Mike19
    Mike19 New Member
    Jun 27, 2008
    I live in West Seattle and I'm an accomplished DIY. I'm thinking about putting an irrigation system in my yard so I can water my grass. I would prefer not to use city water to do this so I'm leaning towards using an underground spherical holding tank that would collect my roof's rain runoff. I'm not sure on how big of a tank I would need or how I would hook up my sprinkler system to it?
    I've researched NORWESCO tanks and the 300 gallon under ground tank with pump platform looks like the solution but I'm not sure. My roof pitch is 6/12 and its square footage is around 2500. My lot size is around 5000 square feet and maybe 2300 of that would be considered my yard. Would a 300 gallon tank do the job? Would Seattle's rain be able to fill up the tank so I would have enough during Spring and Summer? If so, how do I hook up the sprinkler system to it so the pump can provide the lines with water?
  2. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    It's the thought that counts. Now you can let it go. 2300 sq ft of yard can easily drink up 5000 cu ft of water in a season, and that's over 35000 gallons.
  4. drick
    drick In the Trades
    May 16, 2008
    I have a 1/2 acre lawn. When its 90 plus degrees outside it uses roughly 1600 gallons of water a day. Your lawn is much smaller, so assuming a similar light clay like soil type you would need 177 gallons a day. Sandy soil will require significantly more. I don't think the savings you would realize by using rainwater would offset the cost of just using city water.
    -rick
Similar Threads: Sprinkler system
Irrigation / Sprinkler Forum Flow required to properly blow out sprinkler system Oct 22, 2016
Irrigation / Sprinkler Forum Inground sprinkler system SPLITTER? Sep 8, 2016
Irrigation / Sprinkler Forum Didn't see a sticky, but need troubleshooting tips for sprinkler system Jun 21, 2016
Irrigation / Sprinkler Forum How to turn on sprinkler system. Jun 18, 2016
Irrigation / Sprinkler Forum DIY sprinkler system recommendations Apr 14, 2016
