Sprinkler leak at the tee.
Discussion in 'Irrigation / Sprinkler Forum' started by ny941932, Jun 3, 2008.
  1. ny941932
    ny941932 New Member
    Jun 3, 2008
    I had a leak between the tee and the pipe. I decided to replace it, bougtht a new tee. Still leaking.
    This is one solid pipe, not 2 ends spliced together. It has a hole in it and the tee is made from 2 halves (top and bottom). I simply fitted it onto the pipe and tightened the nuts.
    This could be a very basic issue.
    Am I supposed to seal with something between the pipe and the tee somehow?
    It's leaking quite a bit, not just dripping.
    thank you.
Similar Threads: Sprinkler leak
Irrigation / Sprinkler Forum Leaking sprinklers when system is off Feb 19, 2014
Irrigation / Sprinkler Forum tips or help on unseens sprinkler system leaks.... May 29, 2010
Irrigation / Sprinkler Forum Leaking sprinkler heads Apr 29, 2010
Irrigation / Sprinkler Forum Leaking Sprinkler Valve Dec 5, 2009
Irrigation / Sprinkler Forum sprinkler valve air leakage... Sep 16, 2008
