Sprinkler heads only coming up halfway
Discussion in 'Irrigation / Sprinkler Forum' started by DaveLew, Mar 15, 2012.
  1. DaveLew
    DaveLew New Member
    Mar 15, 2012
    California
    The sprinklers on my lawn is only coming up halfway. They were all working before. I turned the zone on the other day at the valve manually and I'm not getting enough pressure to fully raise the sprinkler heads. Sometimes I can get the sprinklers to stay up by pulling them up manually, but only after running the zone for maybe 5 minutes, otherwise they drop back halfway down. I'm thinking there must be a break in the zone causing a pressure drop.
    Trying to find the break will be a challenge. An earlier post mentioned caping the sprinkler heads and looking for wet spots after a while. But since my issue is in a lawn, I think that might be difficult to spot thru the grass.
    Can the valve contribute to this? The valve is wide open is full ccw position.
    Any help would be appreciated. Thanks.
Similar Threads: Sprinkler heads
Irrigation / Sprinkler Forum Sprinkler Heads Feb 5, 2012
Irrigation / Sprinkler Forum Removing sprinkler heads Jun 8, 2011
Irrigation / Sprinkler Forum Ideas on sprinkler heads Jul 20, 2010
Irrigation / Sprinkler Forum Rainbird1800 sprinkler heads along sidewalk Jun 22, 2010
Irrigation / Sprinkler Forum Leaking sprinkler heads Apr 29, 2010
