Sprinkler head problem
tomtom
Texas
I have Rain Bird rotor sprinklers installed in my backyard. One of the sprinklers will not turn when all others will. Is there something I could quickly check?
SteveW
DIY Senior Member
Omaha, NE
I've had the occasional rotor which didn't turn, and I just manually turned it back and forth a couple times until it started to move again.
In the end, though, this is usually a sign that the head needs to be replaced.
Gary Swart
Yakima, WA
If these are the kind with a large case with a lid, you can get replacement innards. You will need a special tool that will grasp the hex nut at the base of the rotor.
WorthFlorida
Solutions
Orlando, Florida
All rotors eventually fail no mater what brand. Some seem to last forever and some last maybe a year. I only changed out a Rainbird brand just the other day and do all fail the same, stop rotating where the head goes counter clockwise to clockwise rotation, There easy to replace but do cost $8-$18 each.
wayneda
Houston, TX
sprinklerbros.com
It may be that the rotor has debris blocking the gears causing it not to rotate. Try carefully taking out the insides and rinsing them with water to get all the dirt and rocks out.
Another likely cause is that the sprinkler is worn out and the gears inside are stripped. If this is the case, you will need to replace the sprinkler. Eventually you will have sprinkler heads that will fail, just replace them.
Wayne
Sprinkler Bros
