AdamGoldMiner
Greetings, I'm a noob to the forum and would love if some of you more experienced folks would help me think through this situation:
Our home that we purchased last summer has a spring as its water source. During testing the spring maintained 5gpm for about 30 minutes before slowing and then leveling off at 1.5 gpm for 4 hours. After living in the home we've had plenty of water except for times like the following: We got home from camping, washed both cars and the trailer, ran two loads of laundry and then everyone (2 adults 2 children) started trying to take showers...showers didn't work...trickle spurt, etc.
The spring itself is only a few feet deep with a 3 foot diameter culvert for a wall, with a pump house built on top. I'd like to install a storage tank (I'm thinking 750 gallon) next to the spring house to hold a reasonable amount of water to be filled by the spring before being pumped into pressure tank, then up to the house. I'm thinking to use a KARI float switch in the tank to control when water is pumped from the spring.
The spring produces plenty of water for normal, ordinary daily use, it's those extreme high-use conditions that cause the lack of water.
My questions: Is 750gal tank enough (I estimate that's 2 days storage)? Not enough?
Since the current well pump is for the spring could I use it to pump water from the tank to the house, and replace it with a new pump from the spring into the tank? In that case, what kind of pump?
Should I use a float in the spring to turn off that pump if the water gets too low, or some kind of a cavitation sensor to shut off the pump if it sucks air? What's the best way to deal with that?
Any input would be appreciated.
