splitting water line
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by djwater, Jul 10, 2005.
  1. djwater
    djwater New Member
    Jul 10, 2005
    Hi, I am a completely novice plumber and I am trying to add a bottleless watercooler to my kitchen setup. It involves what they claim is a 10 minute install with a standard sized waterline. I would like to put the cooler right next to the refrigerator, which already has a waterline going into it and is the only waterline in that area of that kitchen. Is it feasible to split that waterline and use it for both the refrigerator and the watercooler? If so, is it something a novice can do, or should I hire a professional? How much would a plumber charge to do something like this? Thanks in advance, plumber people!!
  2. jadnashua
    What size water line does the thing require? Most of the small tubing used for refrigerators may not be big enough for two devices. It isn't hard to cut that line, put in a T-connector and then run it off to multiple devices, but again, it may not have sufficient size. My unprofessional opinion.
  4. djwater
    djwater New Member
    Jul 10, 2005
    Thanks for the quick reply. The refrigerator is a whirlpool, it is a mid-sized unit in a 1-bedroom apartment in NYC. The water line going into it would really just be used for an ice maker which is used a light to normal amount. No idea what size water line is going into it now. The water cooler I am going to install calls for a 1/4 inch outside diameter water line, and I would probably be using like 5 gallons of water a week at most, not too serious a load. The product I am getting is from http://www.aquaverve.com in case you are curious. Thanks!
  5. jadnashua
    Sounds like a T connection, and some more pipe. One of the pros may have some thoughts....
Similar Threads: splitting water
Plumbing Forum, Professional & DIY Advice Splitting a basement bathroom into two. Part 1) plumbing the second toilet Mar 13, 2010
Plumbing Forum, Professional & DIY Advice 6" Certainteed Pipe splitting Apr 28, 2008
Plumbing Forum, Professional & DIY Advice Plumbing for a gas water heater Yesterday at 8:22 PM
Plumbing Forum, Professional & DIY Advice Occasionally hearing water running through vent stack, but no water is running. Yesterday at 6:13 AM
Plumbing Forum, Professional & DIY Advice It's Hot! Drink some more water. Yesterday at 3:38 AM
