Split tub to shower help!
Discussion in 'Shower & Bathtub Forum & Blog' started by Diamondintheruff, May 16, 2007.
  1. Diamondintheruff
    Diamondintheruff New Member
    May 16, 2007
    Frist off Hello All!@
    here is my issue. I just bought a house with a whirlpool style bath tub and NO shower (how these people lived with out a good shower i dunno) so my question is is it possible to some how add a shower head to it? the faucet is already built into the tub ? i am sure it is possble i am just looking for someone to guide me in the dirition of what plumbing parts it will take to make it possbile to add a shower head to this set up?
    Thanks!!!:D
  2. jimbo
    jimbo Plumber
    Please post a picture if you can. If you have a conventional tub filler spout, you could replace that with one which has a fitting to attach a hand-held hose, which can be placed in a bracket up on the wall.
    If you have a roman tub filler, this will not be so easy.
    I would have some concern as to whether the walls were built to accept water as in a shower.
  4. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Spout with Shower Adapter
    This is what Jimbo is talking about, but it will probably only work if you have a standard tub spout.
  5. Diamondintheruff
    May 16, 2007
    AH yes i am not sure what a roman one looks like could somoene please post a pic for me? i am going to have the house inspected within the next 5 days i will try and snap a pic for you guys to see! Thanks! :D
  6. Diamondintheruff
    May 16, 2007
    :EDIT: well i looked up what a roman one looks like and no i for sure have a standard. now the question is do they screw off or do u need somesort of puller? thanks guys!
  7. jadnashua
    Spouts either are screw-on or push on. If it has a set screw that holds it from the bottom somewhere, it is push on. If it has no holes with an accessable screw, it is probably a screw on. One, you just unscrew. The other, loosen the set screw and pull it off. In either case, you might have to cut through some caulking before you can remove it.
  8. Diamondintheruff
    May 16, 2007
  9. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    the way the walls were built will determine how well water slips away when it seeps under the tiles. Under the caulking where the tiled wall meets the tub, there may be a lot of mold later. I wouldn't worry about it. Just in case you wanted to know. Now that the tub is becoming a tub-shower. I wouldn't let the shower spray onto the walls much.
    david
Similar Threads: Split shower
Shower & Bathtub Forum & Blog How to split supply line to go to shower and bath Sep 3, 2008
Shower & Bathtub Forum & Blog Split Durock Seams in a Shower wall? Nov 4, 2007
Shower & Bathtub Forum & Blog Renovating - Split Shower/Tub from original Nov 4, 2005
Shower & Bathtub Forum & Blog Lustrolite shower wall covering Monday at 11:17 AM
Shower & Bathtub Forum & Blog Delta rain can shower head install Sunday at 7:12 AM
