Spigot to ice chest
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Flyinpig14, Aug 14, 2013.
  1. Flyinpig14
    Flyinpig14 New Member
    Aug 14, 2013
    Louisiana
    Hello everyone,
    I'm not sure if this is the right place to ask this or not, but I thought maybe someone here could help me. I am building a wooden ice chest box around an ice chest. The ice chest doesn't have a drain plug, and I am trying to figure out how to add a spigot to the side. I already ruined one ice chest by drilling a hole and apparently using all the wrong parts to try and add this spigot. It doesn't need to be anything fancy, just any suggestions would be greatly appreciated. I am a complete idiot when it comes to this stuff so please take it easy on me!
    Thanks in advance!
  2. dj2
    dj2 Well-Known Member
    Aug 13, 2013
    California
    Don't you think it would be easier to buy an ice chest with a built in spigot?
    But just in case you can't do that, a spigot most likely comes with a rubber washer, a metal washer and a nut, that go inside the chest to plug the hole and to stop leaks.
  4. jadnashua
    It really depends on what the chest is made out of. A picture might help.
    If it's something that is soft, like a plastic, you may need to bond it in place rather than try something to make a compression seal (i.e., with a nut and washer). There are some good waterproofing compounds out there - one that comes to mind is KerdiFix, which will stick to nearly anything, is flexible, and waterproof. It's kind of expensive, but comes in, I think, three different sized tubes - the smallest would be way more than enough.
  5. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
    Google: draft beer faucet and shank
    and see if that will work
  6. mrbeing123
    mrbeing123 New Member
    Dec 5, 2012
    Louisiana USA
    I can try to help. We uses these a lot for drums, hoppers and tanks where I work (oil/gas chemical blending company). Might want to check the miniature ones but I see there are no gaskets on it. With these, you would then have a female threaded fitting, where you could add whatever plumbing too it that you want. But like jadnashua said, the ice chest's insulation might compress too much to use something like this. Again like he said, bonding it with a proper adhesive might be in order. If I had to say what kind of adhesive, I would go with maybe an acrylic based epoxies specifically made for plastics.
    http://www.mcmaster.com/#tank-pipe-fittings/=o3bvye
Similar Threads: Spigot chest
Plumbing Forum, Professional & DIY Advice Add garden water valve/spigot to irrigation main line Mar 22, 2017
Plumbing Forum, Professional & DIY Advice Leaking frostfree spigot Mar 4, 2017
Plumbing Forum, Professional & DIY Advice ABS into old hub & spigot pipe? Feb 5, 2017
Plumbing Forum, Professional & DIY Advice Hose spigot leak in concrete slab! Jul 18, 2016
Plumbing Forum, Professional & DIY Advice Water Spigot Pressure Jul 5, 2016
