Spigot Leaks Inside House
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by kylerodland, Feb 3, 2009.
  1. kylerodland
    kylerodland New Member
    Feb 3, 2009
    well...just like the title says my spigot leaks into my home, only when it's on. not sure why? i guessing i need to replace the whole thing. does anyone have suggestions for what kind of spigot i should replce it with? maybe i don't have to replace the entier thing?
    i don;t know much. i'm a novice.
    Thanks
    -Kyle
  2. Terry
    Aug 17, 2004
    [​IMG]
    If it's a frost free faucet, then the tubing in the wall may have split from freezing.
    Complete replacement is the answer.
    [​IMG]
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The usual cause of frost free valves breaking is the hose being left attached during freezing weather. This prevents the water from draining.
  5. kylerodland
    Feb 3, 2009
    thanks guys, i'll replace it. should i use the which spigot is the best to buy? i've also read about using a ball joint faucet, what are your thoughts about that?
    -Kyle
  6. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Terry's recommendation can't be beat.
  7. Gary Swart
    Sep 1, 2004
    Yakima WA
    I don't think a ball valve would work as a frost free. The mechanics of a frost free has the actual shut off occurring inside the house. See the diagram previously posted. A ball valve turns off/on on the outside. Also, it is much harder to regulate flow with a ball valve.
Similar Threads: Spigot Leaks
Plumbing Forum, Professional & DIY Advice ABS into old hub & spigot pipe? Feb 5, 2017
Plumbing Forum, Professional & DIY Advice Hose spigot leak in concrete slab! Jul 18, 2016
Plumbing Forum, Professional & DIY Advice Water Spigot Pressure Jul 5, 2016
Plumbing Forum, Professional & DIY Advice Locating Shutoff Valve for outdoor spigot Jun 30, 2016
Plumbing Forum, Professional & DIY Advice Broken Spigot Apr 26, 2016
