SpiderWeb II - Review of Custom Building Products new Uncoupling Mat
Discussion in 'Shower & bathtub Forum & Blog' started by johnfrwhipple, Apr 9, 2013.
  1. jadnashua
    21,924
    No idea what kind of strength you'd have with a pull test. The vast majority of stress on tile is in shear, either from bending or if on a vertical surface, just from the weight. As noted, at least as I remember it, the 50psi industry rating is for shear, not pull. I'm not sure I've seen a pull test requirement.
  2. johnfrwhipple
    johnfrwhipple I love these ACO Shower Drains - Best in Class
    4,008
    North Vancouver, BC
    Post(s) removed by John Whipple
  3. jadnashua
    21,924
    On a wall would be more in line with my understanding of the test procedure.
  4. johnfrwhipple
    4,008
    North Vancouver, BC
  5. jadnashua
    21,924
    I think the grout simulates a full wall install better, since it ties the stuff together. Makes it harder for the membrane to shear off, since it's sharing the load across a larger area. But, I have not read the details of the actual test procedure, so may be misinterpreting it.
  6. johnfrwhipple
    4,008
    North Vancouver, BC
    SpiderWeb 2 vs Ditra & Noble Seal TS (Head to Head Challenge)
  7. johnfrwhipple
    4,008
    North Vancouver, BC
    Installing Ditra with Ardex AF207
  8. johnfrwhipple
    4,008
    North Vancouver, BC
    Thin-set used in testing
  9. johnfrwhipple
    4,008
    North Vancouver, BC
  10. johnfrwhipple
    4,008
    North Vancouver, BC
    Spider Web 2 Testing
  11. johnfrwhipple
    4,008
    North Vancouver, BC
  12. jadnashua
    21,924
    The industry tests are after 28-days, the standard for cement based products. After the first week, it has most of the strength. But, also consider that cement continues to gain strength for years, the 28-days was a calculated compromise based on typical construction timelines representing 'typical' strength.
  13. johnfrwhipple
    4,008
    North Vancouver, BC
  14. johnfrwhipple
    4,008
    North Vancouver, BC
    Testing day is here at last
  15. johnfrwhipple
    4,008
    North Vancouver, BC
    Pictures of the shear testing control test
  16. johnfrwhipple
    4,008
    North Vancouver, BC
  17. johnfrwhipple
    4,008
    North Vancouver, BC
    Uncoupling membrane - shear testing (Ditra with Laticrete 254 Platinum)
  18. jadnashua
    21,924
    What's the bonded surface area of the brick? As has been said, a membrane should hold at least 50#/sqin. From a practical viewpoint, I think you've proven you're not likely to strip a tile off the wall easily once the mortar has cured some, at least for Ditra, you've tested.
  19. johnfrwhipple
    4,008
    North Vancouver, BC
  20. johnfrwhipple
    4,008
    North Vancouver, BC
    Ditra Shear Testing - Failure point 1470 pounds
Similar Threads: SpiderWeb Review
Shower & bathtub Forum & Blog Review of Tuscan Tile Leveling System Jul 10, 2014
Shower & bathtub Forum & Blog Wifi Thermostat by NuHeat - Review Jan 30, 2014
Shower & bathtub Forum & Blog Additional pictures for "Please review this shower pan install. Did I pay a lot of $$ Nov 19, 2013
Shower & bathtub Forum & Blog Please review this shower pan install. Did I pay a lot of $$ for subpar work? Nov 19, 2013
Shower & bathtub Forum & Blog CGC Durock Shower System - Review Oct 17, 2013
