Special Drain for Vessel Sink without Overflow?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by sanrico, Dec 6, 2009.
  1. sanrico
    sanrico New Member
    Oct 4, 2009
    Land of Enchantment
    Me again.
    We bought a vessel sink without overflow for our bathroom. We bought a Kingston Brass faucet (model KS8078DL), which came with a pop-up drain. Nowhere in the literature for this faucet does it say whether this drain is designed for overflow sinks or non-overflow.
    Is there a way I can tell? I don't know enough to just look at it and know if it's the proper drain or not.
    Thanks again!
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Overflow or not makes no difference.
    many manufacturers are deleting the overflow because it is a place to harbor nasty bacteria.
  4. sanrico
    sanrico New Member
    Oct 4, 2009
    Land of Enchantment
    First off, thank you kindly for your quick response!
    But I read that if there is no overflow on a vessel sink, you need a specific type of drain or the sink will drain very slowly. Isn't that true?
    I have a p-trap all ready to install, but I read this about the vessel drain and I stopped to ask the question.
  5. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    The only issues that I've heard about were where a grid drain had small holes which made it slow to drain. I don't think you'd have an issue with a pop up drain.
  6. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Yep, no issues... have at it
  7. jimbo
    jimbo Plumber
    If the sink has no overflow, you will need a drain without overflow. A drain for sink with overflow, whether pop up or grid, will usually be too long for the thickness of the sink. Grid drains can have a problem due to small holes. If you swirl the water with your hand it goes down. If you drill out about 6 holes to about 9/32, that helps.
    Any good supply house will have a drain without overflow.
Similar Threads: Special Drain
Plumbing Forum, Professional & DIY Advice Special attachment from drain/overflow to ptrap Sep 26, 2006
Plumbing Forum, Professional & DIY Advice Special Basement Drain Oct 20, 2004
Plumbing Forum, Professional & DIY Advice Wilkins 975XL special tool Oct 5, 2016
Plumbing Forum, Professional & DIY Advice Is there a special shut-off for higher than WH temp water? Sep 14, 2016
Plumbing Forum, Professional & DIY Advice Help! We need a toilet to help with my special needs's son's BMs Jan 1, 2016
