spalling concrete
Discussion in 'Remodel Forum & Blog' started by tregg, Jul 17, 2010.
  1. tregg
    tregg New Member
    Dec 27, 2009
    Iowa
    What are the remedys for spalling concrete? It's in my basement but not on a load bearing wall. It is next to the stairs going up and is on the edge of the attached garage so there is earth on the other side of it.
  2. jadnashua
    There are various concrete products designed to top your slab. Will this ever be finished with something on it? Maybe tile, carpet, etc.? Then, it may not matter.
  4. tregg
    tregg New Member
    Dec 27, 2009
    Iowa
    Thanks Jim!
  5. jimbo
    jimbo Plumber
    San Diego, CA
    jad....I think he is talking about a wall surface, not a floor slab. He mentions earth on the other side, and a contiuously wet wall which was not waterproofed on the outside can fall victum to spalling.
  6. jadnashua
    Hydrostatic pressure may make any topping fail. You may want to call the manufactuer of the product. Two companies that make stuff for this are Ardex and Custom Building Products. There are others. Check their websites, read the spec sheets, and then call and talk to a tech to find the best product. Some of them require a primer first (a bonding agent), and that usually requires the area to be dry. Depending on the weather and ground conditions, you may only have a narrow window of opportunity to do this.
Similar Threads: spalling concrete
Remodel Forum & Blog Concrete Spalling Jun 16, 2007
Remodel Forum & Blog What to do about chimney (paint/spalling) Oct 2, 2015
Remodel Forum & Blog Attaching to a concrete block wall Jul 12, 2016
Remodel Forum & Blog Concrete slab woes; need new water lines, radiant heat is leaking. Apr 24, 2016
Remodel Forum & Blog Sealing vertical pipe penetrations through Concrete? May 20, 2015
