I currently have two well points spaced twenty feet apart and t'd near the center to my pump. So common math tells me each point is 10 ft away from the pump. If I wanted to add a third point, should I also make that one 10ft away or can I go a little further, say 15 feet. I want to make sure I don't hamper the flow of the other two points.
Thanks You
Thanks You
