Sounds Like The Toilet Is Flushing But It's Not
Discussion in 'Toilet Forum discussions' started by fsoprano, Sep 6, 2011.
  1. fsoprano
    fsoprano New Member
    Sep 6, 2011
    NJ
    My three toilets (upstairs downstairs and basement seem to be flushing by themsleves but it is only making the noise and there is no flush. This started with the basement toilet and now has spread to the other two. Has anyone experienced this with their toilet?
  2. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    What do you really mean when you say it sounds like its flushing? Does it really sound like its filling with water (due to maybe water leaking from the tank through a bad flapper/flush valve), or does it really sound like when you actually flush it? If it is the latter, then maybe time to call Ghostbusters. A flush sound is quite distinct like "Fashooom";) and over with in a few seconds.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Only you know what sound it is making, but I'd be willing to bet the flappers are not sealing and this is causing the toilet to constantly refill. Take the lid off the tank and watch. If it is the flapper, the water level will slowly drop in the tank until the float is low enough to open the refill valve. If you have high chlorine in your water or if you have been using bowl cleaner in the water tank, that could be causing rapid flapper failure. Fortunately, flappers are a quick and DIY easy repair. Lowe's has them.
  5. jadnashua
    Turn the water supply off to the toilets before you leave for the day or before bed, then check them when you come back...odds are, the tank will be empty when you get back.
  6. BobL43
    Mar 25, 2011
    Long Island, NY
    If you have any food coloring, put some in the tank; don't flush. after a few minuts or hours look in the bowl and see if any coloring got into the bowl. This sounds a little like what the Ocean Spray TV commercial guy might do:eek:, but it should show if the flapper is leaking water into the bowl, and causing the tank to constantly refill.
  7. jadnashua
    If you wait too long, both the tank and the bowl will get flushed out, but that is also another possibility.
  8. hj
    The water is leaking from the tank, which causes the fill valve to turn on and refill it. There are several possible causes for the leakage.
  9. fsoprano
    fsoprano New Member
    Sep 6, 2011
    NJ
    Must be a ghost thing because everyone here seems to think it's the flapper or a re-filling issue. I have already opened the back of the toilet when this is happening and there are no flapper issues, no bubbles and I am not losing water. Sorry and thanks for all of your input but this seems to be a mystery as the exact same thing happening to all three toilets seems too remote.
Similar Threads: Sounds Toilet
Toilet Forum discussions Kohler toilet makes leaking sounds, but never refills Today at 12:30 PM
Toilet Forum discussions Toilet sounds like its choking Sep 28, 2006
Toilet Forum discussions Toto UltraMax II Sounds Like It's Leaking Then Makes Strange Noise May 6, 2013
Toilet Forum discussions Fix for the dripping sounds from Aquia Aug 23, 2008
Toilet Forum discussions Hearing weird crackling sounds from bottom of Kohler Highline bowl Jun 25, 2007
