Solvent Weld vs No Caulk
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Blaze, Jan 20, 2007.
  1. Blaze
    Blaze New Member
    Dec 14, 2006
    Office Grunt
    Ontario, Canada
    I was wondering which solution would be best for my situations.
    I am installing an acrylic corner shower (base and walls) from Maxx. The bathroom is on the second floor above my family room.
    Should I use a solvent weld shower drain or a no-caulk shower drain, and why?
    Thanks
    Mark
  2. jimbo
    jimbo Plumber
    If you have access from a ceiling below, I prefer a solvent weld. If this is on a slab or otherwise does not have access, then you will need the no-caulk.
  4. Racer814
    Racer814 New Member
    Dec 24, 2006
    I prefer a glue drain in either instance...just MAKE SURE you get one that you can unscrew the drain after installation in case you have a leak...then tyou can screw it out...re putty and re install...
    actually this is one of the few times I might use silicone over putty.....:eek:
Similar Threads: Solvent Weld
Plumbing Forum, Professional & DIY Advice Solvent welded shower drain is leaking Mar 20, 2015
Plumbing Forum, Professional & DIY Advice PVC solvent weld integrity question Oct 7, 2013
Plumbing Forum, Professional & DIY Advice PC to ABS: Fernco or solvent weld? Oct 22, 2011
Plumbing Forum, Professional & DIY Advice Can I Apply Abs Solvent Over Old Solvent So New Santee Flush With Existing Coupler Tuesday at 4:33 PM
Plumbing Forum, Professional & DIY Advice Cleaning foam and adhesive off abs before solvent cementing Jan 16, 2016
