Solution for caulking between tile and tub
Discussion in 'Shower & Bathtub Forum & Blog' started by mntentman, Apr 30, 2009.
  1. mntentman
    mntentman New Member
    Aug 2, 2008
    I just retiled a tub surround sound with fairly dark tiles and grout. The tub is white. The caulk that matches the grout is a color called "chocolate truffle." It looks good everywhere except where it goes along the tub. I have done plenty of caulking and know how to do it pretty well, but the stark contrast between the dark cault and white tub shows very clearly where it is uneven. I want this to look as good as possible, and am thinking it might be better to remove the dark cault alon the tub and go with a clear caulk. Am I missing a trick to make this caulk perfectly even... am I expecting "perfection" where it is unlikely... or am I best off going with the clear? Thanks for the help!
  2. hj
    You make it "perfectly even" by applying masking tape along both sides of the bead, then removing the tape after striking the cove to give a straight line.
  4. jadnashua
    Clear tends to look shiney, so if you don't want to color match the grout, use white to match the tub.
  5. mntentman
    Aug 2, 2008
    I used the masking tape trick. Looks great now. Thanks. Not sure how I got this old without learning that, but I did.
Similar Threads: Solution caulking
Shower & Bathtub Forum & Blog Old school solution Apr 27, 2015
Shower & Bathtub Forum & Blog Grouting Solutions for Commercial Kitchens : Wednesday May 21, 2014 NTCA Webinar May 21, 2014
Shower & Bathtub Forum & Blog Please help! Fluid Faucets from SSi (Sustainable Solutions) Oct 15, 2013
Shower & Bathtub Forum & Blog Delta and Tankless HWH Solutions Apr 19, 2011
Shower & Bathtub Forum & Blog Is an above floor drain my only solution? May 21, 2010
