Solid Seal on Septic Tank when the lid is removed
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by mrodz, Sep 13, 2013.
  1. mrodz
    mrodz New Member
    Sep 13, 2013
    United States
    Hi all!!
    We had a slow draining toilet and water backed up into the shower so we opened the lids on the septic tank.
    These are screw top pvc lids. One was absolutly solid, like cement had been thrown in, the other full to the brim. Its been raining a lot so we've been out of the house and not using water to see how long it might take to drain into the drain field. Well, when we went to check.... now both are sealed, we hit it with a hammer and NOTHING, Just SOLID. Has this ever happened to anyone?
  2. mrodz
    mrodz New Member
    Sep 13, 2013
    United States
    I can take pictures of the problem if it helps
  4. mrodz
    mrodz New Member
    Sep 13, 2013
    United States
    When I hit it, it sounds kind of hollow, like maybe its not that thick, not sure I'm think just to keep pounding on it and see if it cracks or pops out or something, like a plug. If not maybe Acid?
  5. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Are the solids in tank 1 or tank 2 ?
    Some places do not allow you to work on your own system.
    You have to pay a Fee.
    #2 should go into tank 1 and #1 should go into tank 2.
    If they are both full then you need a Pump Truck, and need to see why it is not working properly.
    Some 2 and 3 tank units water the lawn, and can have a pump failure. But most of them require monthly maintenance, by a law enforcement collector.
    Good Luck.
  6. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    Wrong side of the house for me
  7. mrodz
    mrodz New Member
    Sep 13, 2013
    United States
    We built the house from nothing just 4 years ago, we have all the plans on the septic system and we kept it visible and easily accessible. Well, turns out that it's like a hard plug of debris forming and gettin solid when the levels rose. It got stuck in the tube leading to the pvc lid and just hardened up real quick. I banged with a mallet and a crow bar til it broke, tried not to let too much fall in. After that the mostly liquid side seems to be draining pretty quick and we have a few good days of sun hopefully. I haven't gotten a good look at the other side yet. Plan for now is to see how much it keeps draining and not let too much water down the drains.
Similar Threads: Solid Seal
Pumps and Tanks Well Forum & Blog. Water is life. Pumptec shows solid green but no water is coming thru. Sep 30, 2012
Pumps and Tanks Well Forum & Blog. Water is life. PumpTec Help! Solid Yellow Light Jun 24, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Cup seals always need replacement after year's time. Jan 19, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Seal Cap and/or Drop Pipe Supports/Hangers Dec 20, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Please identify (well seal?) Dec 19, 2016
