Solenoid function on a irrigation valve?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pmaru77, Apr 13, 2009.
  1. pmaru77
    pmaru77 Member
    Nov 1, 2008
    Mech Eng/designer
    California
    Well, while I'm trying to repair/fix my valve leaking problem, I thought I'd ask how a solenoid valve drop the pressure on one side of the diaphram valve so that the diaphram opens to let flow to the sprinklers. I am assuming that there is more pressure on the top of the diaphram when shut, thus shut. So, does the soleniod (retracting type) drop that pressure somehow?
  2. jadnashua
    A solenoid valve is an electrical device...apply power, and it moves a piston. that piston might be attached to a valve or any one of many devices. Sometimes that piston has a spring to return it to 'neutral', and some require reversing the polarity of the field, or a second actuator.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    Sprinkler valve are pilot operated. When the solenoid is off, an internal port allows mains pressure to be applied to the top of the diaphragm. A small spring adds to this pressure, whereas the underside of the diaphragm only sees mains pressure, so the diaphragm remains closed. When the solenoid is activated, it opens a port which bleeds mains pressure from the top of the diaphragm into the outlet pipe. This bleeds faster than the inlet bleed, and thus mains pressure on the underside lifts the diaphragm.
  5. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
  6. pmaru77
    pmaru77 Member
    Nov 1, 2008
    Mech Eng/designer
    California
    Very good......thanks. So the diaphram does have water on both sides as I thought. Also to add, the line pressure has more surface area to push on the top of the diaphram, thus more pressure downward. I think the spring keeps everyone(diaphram) in place and order while adding a little pressure. I still have not figured out why this 75 dollar valve is passing water. I cut it out for now and end capped the line temperarily.
  7. pmaru77
    pmaru77 Member
    Nov 1, 2008
    Mech Eng/designer
    California
  8. jimbo
    jimbo Plumber
    San Diego, CA
    Good point. Hydraulics is all about pounds PER SQUARE INCH
Similar Threads: Solenoid function
Plumbing Forum, Professional & DIY Advice Solenoid valve for shower Mar 31, 2014
Plumbing Forum, Professional & DIY Advice Ultra-Flo one-line Plumbing system (low voltage solenoid control) Aug 13, 2013
Plumbing Forum, Professional & DIY Advice Solenoid safety valves for laundry room? Sep 23, 2010
Plumbing Forum, Professional & DIY Advice solenoid breaker trip Nov 30, 2008
Plumbing Forum, Professional & DIY Advice Solenoid for Outdoor Tankless Aug 29, 2007
