Solenoid for Outdoor Tankless
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by slapjack, Aug 29, 2007.
  1. slapjack
    slapjack New Member
    Aug 29, 2007
    I'm looking at installing an outdoor tankless water heater (Rinnai). The installation manual recommends installing auto drain down solenoids so that if the power fails the unit will drain and not freeze. Has anyone done this type of install? What type of solenoids did you use and where did you get them? Any advice you can provide would be greatly appreciated.
    I'm located in the Atlanta, GA area, so we rarely get temperatures below freezing... but I'd like to be prepared just in case.
  2. hj
    You need a normally open valve that is kept closed as long as there is power to it. IF the power fails the valve reverts to its open position and causes drainage.
  4. slapjack
    slapjack New Member
    Aug 29, 2007
    Here's a link to the installation documentation...
    Page 34 shows a typical install with freeze protection. With this layout, there are (2) solenoids installed. Am I correct in that if power is lost there will also be no water available down line at fixtures? Also, will all the water down line in the hot water pipe also drain?
    Is this overkill or pretty much standard for outdoor units? Also, is there anywhere online you can recommend for me to purchase these solenoids?
    Sorry for all the questions - I just want to do things the correct way and I'm not a plumbing expert (as you've probably already determined). However, I'm a pretty advanced DIY'er and willing to give this a try. Thanks for the help.
  5. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    I would not mess with solenoid valves. What is the chance of simultaneous:
    Power outage AND freezing weather in Atlanta AND you are not there to deal with it.
    The valves must be continuously powered.
    Maybe two valves sitting there powered open for a year or two between power failures will work, and maybe they won't.
    If the improbable happens call a neighbor to open a drain valve.
Similar Threads: Solenoid Outdoor
Plumbing Forum, Professional & DIY Advice Solenoid valve for shower Mar 31, 2014
Plumbing Forum, Professional & DIY Advice Ultra-Flo one-line Plumbing system (low voltage solenoid control) Aug 13, 2013
Plumbing Forum, Professional & DIY Advice Solenoid safety valves for laundry room? Sep 23, 2010
Plumbing Forum, Professional & DIY Advice Solenoid function on a irrigation valve? Apr 13, 2009
Plumbing Forum, Professional & DIY Advice solenoid breaker trip Nov 30, 2008
