soldering soft copper
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by scott99, Feb 6, 2007.
  1. scott99
    scott99 New Member
    Feb 1, 2007
    I was just reading an article that said you can't solder soft copper but need to use a flare or compression joint. Is that correct?
    I just cut out a section that was soldered with a coupler connecting soft to rigid and was planning on doing the same thing.
    I also noticed that my Autocut pipe cutter seems to crush the soft pipe a tad when using it. found on their web site that it's not to be used on soft copper. the area is too tight to use a hack saw to cut it off.
    thoughts?
  2. dubldare
    dubldare Plumber/Gasfitter
    Sep 14, 2005
    Plumber/Gasfitter
    MN/ND
    Get a new cutter. Autocut's, while quick, do a good job of mangling pipe. A normal imp cutter will do a better job and be controlable.
    I've soldered and brazed soft copper countless times, probably equal to what I've flared.
    Post the article, if you will.
  4. scott99
    scott99 New Member
    Feb 1, 2007
    found it on ************.
    I'm going to proceed, but noticed that my coupler is pretty tight on the soft copper. probably since it's a bit out of round. is there a chance that the fitting will be so tight solder won't take?
  5. hj
    solder
    The tighter the fitting, up to a point, the better the joint will be. It is the loose joints that do not solder properly.
  6. Racer814
    Racer814 New Member
    Dec 24, 2006
    ^what he said...
    and for the record, Bridget solder will fill a "loose" fitting better than any....and when you are dealing with soft copper you are going to have loose/tight joints
  7. hj
    solder
    The capillary attraction that makes the solder flow to the "end" of the joint DEPENDS on a tight joint. If the joint is loose the only way it is going to fill the joint is if it is on a vertical pipe and you "pour" the solder into it.
  8. Racer814
    Racer814 New Member
    Dec 24, 2006
    right on about the capillary action......when I say "loose"....I'm using that term loosely
    I mean it is not an optimal fit...like a horizontal run of copper that will sag downwards in the fitting until you get it supported....that "play" in the joint is what I'm talking about and Bridget solder is the best solder I have ever used whether the joint is "tight" or "loose"
Similar Threads: soldering soft
Plumbing Forum, Professional & DIY Advice Water smells like soldering after softener install Mar 2, 2013
Plumbing Forum, Professional & DIY Advice Ice Maker Box Soldering Jan 30, 2017
Plumbing Forum, Professional & DIY Advice Idiots and fire. Soldering in a wall Jan 11, 2017
Plumbing Forum, Professional & DIY Advice Help soldering a split copper fitting Dec 28, 2016
Plumbing Forum, Professional & DIY Advice Sweat soldering tips/tricks Dec 22, 2016
