BridgitWolf
Hi All! I hope someone can help me with this problem... single DIY mom here...
I had a leaky hot water valve underneath my kitchen sink, so I set about replacing it: I heated up the valve fitting, removed it, polished the exposed copper as best I could, fluxed, and tried to sweat a new fitting in its place. I mangled the job! I probably used too much flux, and didn't get the old pipes clean enough... Anyway, I didn't even run water through the pipe, I could see that the sweating job wasn't going to hold.
So, I just cut the pipe below the first fitting, and installed a whole new pipe assembly and valve using Lowe's compression fittings. Water flows great now -- but the hot water has a horrible smell/taste! I'm guessing that it's fumes from the burnt flux that migrated through the pipes...? Is that typical? I tried running hot water for 10 minutes, but the smell doesn't seem to go away.
Also, this hot water line T's off to the dishwasher, which also gets the stinky water -- so I guess the smell migrated into that hose too... I figured I'd have to replace all the lines downstream of the section that I originally sweated and replaced. Does anyone have advice for an easier fix, or any experience with something like this?
Thanks, B
Thanks, B
