Soldering copper to brass??
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by David Einhorn, Jan 19, 2013.
  1. David Einhorn
    David Einhorn New Member
    Jan 19, 2013
    Texas
    I just discovered a leak coming from my shower body and see that the water supply pipe (copper) was soldered to the brass fitting on the shower body. The brass fitting is threaded. Is this code? Why would any professional plumber do this? Do I have recourse with the original plumber that performed the work? photo.jpg
  2. nukeman
    nukeman Nuclear Engineer
    Nov 20, 2009
    Nuclear Engineer
    VA
    That connection is normal. Many shower valves give the option to either thread on a female fitting or you can put the copper pipe in the socket and solder. Personally, I like the solder connection and that I what I used on my shower.
    How long ago was this done? It may be that the solder didn't get fully into the joint (joint not clean enough, not the right amount of flux, not enough solder, etc.). It should have been inspected for leaks at the time of install, but if the leak is very small, the leak may not have been detected.
    If it was recent work, you could call the plumber back. If it has been that way for some time, you may need to get another plumber to fix it. If it is really old, it may be a good time to replace the valve and trim.
  4. Terry
    Aug 17, 2004
    Plumbers prefer soldering the pipe to the valve body. That's four fewer joints to leak.
    It just needs to be dissasembled and resoldered.
    Remove the cartridge while doing this.
    And yes, it may be a good time for replacement if this is old. Though the valve does look to be pretty recent.
  5. David Einhorn
    Jan 19, 2013
    Texas
    The work is less than 4 years old, so I think I can avoid a full replacement job. I'm wondering if the plumber will be willing to fix their work from that long ago. What's the industry norm on warrantees for workmanship?
    Thanks for the replies!!
  6. jimbo
    jimbo Plumber
    San Diego, CA
    tail lights!
  7. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I don't know any trade that is going to eat labor after the first year has passed.
  8. hj
    quote; Why would any professional plumber do this? Do I have recourse with the original plumber that performed the work?
    Professional plumbers PERFER to do it that way. Here, the warranty would be two years, by state law. It is unlikely ANYONE would do the repair as a "warranty item".
  9. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    Looks like applying heat to that joint was scorching the very- close wood above it and possibly a little caution was used which may have caused a less than perfect joint?
  10. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    generally it's one year
Similar Threads: Soldering copper
Plumbing Forum, Professional & DIY Advice Help soldering a split copper fitting Dec 28, 2016
Plumbing Forum, Professional & DIY Advice Copper Plumbing, Corroded from Water/Age or Sloppy Soldering and not wiping flux? Mar 3, 2014
Plumbing Forum, Professional & DIY Advice What's the most reliable way to go from copper to pex without soldering? Apr 15, 2013
Plumbing Forum, Professional & DIY Advice Copper to pex without soldering? Mar 21, 2013
Plumbing Forum, Professional & DIY Advice Small leak in new copper soldering. Feb 28, 2012
