Soldering copper fitting with teflon tape on the thread end of it
CountryBumkin
Active Member
Orlando, FL
I'm installing a Steam Generator. I have to solder a copper 90 deg fitting onto a short threaded copper fitting which is threaded into the Protection Valve. Thiscopper fitting has threads on one end a slip coupler on the other end.
Since I can't thread the fitting into the Steam Generator once the 90 is installed, I have to install the threaded fitting first then solder the fitting.
So my question is, will the teflon tape on the copper threads burn/melt off during the soldering? I'll try to wrap threaded part with wet rag - but the whole fitting is only two inches long.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
Do it in a well ventilated area especially if you have birds. There have been many cases of dead birds due to Teflon cookware.
Cacher_Chick
Test, Don't Guess!
That valve should never pop during normal operation, so I wouldn't worry much about the tiny bit that may leak past the threads if it were to.
Dlarrivee
Canada
It will certainly burn if you're heating the same fitting and soldering the other end of it.
I would solder a short chunk of pipe to the threaded fitting first, then tape/thread it in, then solder the 90 to the short pipe... You'll have more room between the torch and the tape, more copper to soak up the heat, and more room for wet rags etc. etc.
LLigetfa
NW Ontario, Canada
I assume every threaded copper fitting will have a straight section of pipe sweated onto it. Just sweat the straight part without the elbow and then thread it in place, sweating the elbow afterwards.
CountryBumkin
Active Member
Orlando, FL
Good point. If the valve pops/opens, anything that drips will go into the drain pan.
I can't add much of a straight section because the pipe needs to clear the top edge of the drain pan. Not much room to exend the 90 downward.
Is there any concern that I could damage the pop-off valve from the heat?
DonL
Houston, TX
A lot of that PTFE tape is rated for 500 deg F.
Check what the rating is for the tape that you are using, Then do not exceed that temp.
Some of the cheap plastic tape is not even Teflon. Don't let the looks fool you. Check the specs.
CountryBumkin
Active Member
Orlando, FL
You're right. I need to sweat a short (maybe 3 inches) straight piece into the threaded fitting then sweat the 90 onto that. But even then, my 90 is only about 1/2 inch away from threaded coupler. I guess I'll give it a try and see what happens.
PS. No birds in house - just birdbrain wife.
If you are referring to the connection to the pressure relief valve, (since it is a steam generator it has NO temperature sensing function), there is NO pressure in the line so it makes little difference whether the Teflon melts or not.
Ballvalve
northfork, california
The bottom valve looks like a drain doesnt need anything, maybe a street el hand tight.
The union is a no brainer - take it apart
The relief valve can have a brass nipple and el attached to it. Supposed to go outside anyway.
Maintenancemouse
Maryland
Could he us a minimum length strait into the threaded fitting, then use a push connect (shark-bite) 90 ?
or maybe a low heat solder?
CountryBumkin
Active Member
Orlando, FL
Exactly.
I don't see why any of that stuff needs to be soldered in place...?
I think you're right. Brillant! Why don't I just install a NTP to PEX coupler and use that to get the drain, flush valve, and relief valve, to the outside? I have plenty of 1/2 inch PEX tubing and fittings. That would sure make the drain runs alot easier.
On the pressure relief valve, if it ever opens the discharge will be hot. Should I run some length of copper first then switch to PEX? I don't want to melt the PEX.
If that relief valve EVER discharges it will be at 250 degrees and WILL melt the PEX no matter how much copper you have between it and the valve. Use ALL copper.
David Palmer
South Georgia
So my question is, will the teflon tape on the copper threads burn/melt off during the soldering? I'll try to wrap threaded part with wet rag - but the whole fitting is only two inches long.View attachment 14637
You can safely solder a fitting that has been thread taped. I actually use thread tape in conjunction with liquid thread sealant, for I use both when doing Water lines. I do it both on pop-off lines as well as threaded ball valves (If I have to) on Therma Star TS11-120-1s, Standard HW Heaters, Commercial Rotisserie Ovens, Steamers, Water lines from 1/4 to 2.5" ect ect. I have never had a leak as a result of sweating a fitting with thread tape. As long as you take care not to heat the tape directly under flame, there will be no problems.
David Palmer
South Georgia
It works but taking the time to pre-sweat is not always possible, or even worth the hassle. I had a water line repair, 25ft over a sales floor that afforded me no room or time to pre-sweat anything. Thanks to that experience and 6 years later, I NEVER waste time pre-sweating male adapters because you just don't have too. As somebody else said, as long as you use real Teflon, you won't have any trouble.
Dlarrivee
Canada
Usually when I'm using a male adapter it is for a plastic laundry box, or an outside hose bib and I'd rather work away from the plastics or tight wood spots, than close to them.
If he is worried about getting things too hot, then he can pre-sweat, if he is skilled enough to work right against the generator itself, then all the power...
Tom99
St Pete, Fl
I had a similar problem. You know, after you solder it, you're going to suspect that the tape will have melted and/or at least loosened up. But there's no way to check it then. To give myself peace of mind, in a similar situation, I soldered 3 inches of pipe to the fitting then applied tape and twisted it in, nice and tight. Then I used a straight fitting with more pipe. Three inches away, the heat probably won't affect it.
