Solder won't let go
Discussion in 'Water Heater Forum, Tanks' started by MRC, Jun 26, 2011.
  1. MRC
    MRC New Member
    Jun 26, 2011
    Seattle
    Hello all~
    Hey my line going from the expansion tank into the WH has the pressure fitting /nut on the WH end and solder off the expansion tank "t" fitting. This is a flex line and it has a slow drip/leak. (perfect for waterboarding;))
    The nut came off just fine but the solder will NOT let go.
    Question - The tank is vertical & above the intake line. Is there water 'trapped' in the line via vacuum?
    I have released the pressure from the expansion tank & still no dice.
    Help?.......
  2. Terry
    Aug 17, 2004
    Have you opened up all the faucets above so that they can drain down?
  4. MRC
    MRC New Member
    Jun 26, 2011
    Seattle
    yuppers. let them drain for a good 30 minutes first thing.
  5. MRC
    MRC New Member
    Jun 26, 2011
    Seattle
    Ok...so the trick was to get the conection REALLY hot.....I mean to the point where it was burning 18 inches down the line.
    So new question. I am very used the running NEW plumbing & joints. Do I need to replace this entire T or simply get the joint hot again and clean it out prior to soldering in the new line?
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Copper fitting can be cleaned an reused. That is a great thing about copper. However, it is somewhat tedious to do so. Now, if it's late at night and you are a long way from an open supply house, then yeah, clean the old one. Otherwise, I would spend the few cents it costs for a new tee and be done with it. So, it's your choice. It's likely the problem you had getting the joint apart was some water remained in the pipe. It doesn't take much. Make very certain the entire pipe is empty and dry before trying to solder your new joints.
  7. MRC
    MRC New Member
    Jun 26, 2011
    Seattle
    Done and done. Opted to clean up the inside of the T and close it up. No runs, drips or fouls.
    Thanks for the help guys.
    MC
  8. hj
    quote; where it was burning 18 inches down the line
    That was NOT burning it was heated steam from water in the line. When you say you "relieved the pressure in the tank" does that mean you depressed the air valve to let it out? IF so the tank was still full of water. You had to turn off the hot water pressure then let the faucets run until the flow stopped, and even then there might not have been enough air in the tank to push all the water out so you might have had to connect an aircompressor and inject air until NO water flowed from the faucet.
Similar Threads: Solder won't
Water Heater Forum, Tanks Hot Water Heater Pilot Won't Light Sep 24, 2016
Water Heater Forum, Tanks Water heater won't drain Dec 15, 2015
Water Heater Forum, Tanks AO Smith Water Heater won't ignite. Dec 12, 2014
Water Heater Forum, Tanks water heater pilot light won't stay on May 7, 2014
Water Heater Forum, Tanks New Ruud gas water heater won't maintain temp Mar 14, 2013
