I am installing faucet fixtures on the side of a new tub. The faucet requires a tee connection to be soldered between the hot and cold faucets. I will also need to install threaded connectors on the hot and cold feeds to the faucets. I am going to use braided flex hose with 1/2" connectors.
I was going to use all copper connectors but I just saw an episode of TOH and they were solder brass fittings to a copper line. The brass fittings look like they are made better than copper.
Can I solder Brass fittings to the copper faucet lines? Is there any benefit? Any tips on solder all the connections? I have not done this before, but I have watched several videos on soldering copper pipe.
Ron OKC
Ron OKC
