softner or filter needed?
Discussion in 'Water Softener Forum, problems, installation and r' started by ugabulldog, Nov 11, 2010.
  1. ugabulldog
    ugabulldog Member
    Nov 27, 2007
    Northeast GA
    My drilled well water tested .41 ppm for iron and 40 ppm (2.3 gr/gal) for hardness. My only concern is staining fixtures and clothes. Do you think i need one, and any advice on softener and/or filter? Does a sand filter work on iron?
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    A sand filter may work, I am not sure about the area that you are in, I know where I am at for the most part as there are still things that come up that are a puzzle even after 20 years..
    A softener most likely will work, but your water temp is different that what I deal with, here the average temp is 35F... yours is another question.
  4. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    A properly sized softener should do the trick. Have your local water fitration company come out and size it for you or you can find a ton of sites online that will give you that information. Water conditions alone are not enough for us to do that here without somee further information.
  5. biermech
    biermech Previous member
    Sep 13, 2008
    Owner SWS Systems
    ocala, fl
    A BIRM (Best Iron Removal Media) filter will remove the iron. There is no salt needed or any other regeneranet for the system. That means very limited maintenance required.
  6. Gary Slusser
    Retired
    A sand filter will not remove ferrous/dissolved iron, only ferric/oxidized iron/rust particles. Sand would only work IF you oxidized the ferrous iron first (into ferric iron particulate matter [sediment]) and then sand would filter them out.
    To use BIRM, you must meet some requirements like no H2S gas etc..
Similar Threads: softner filter
Water Softener Forum, problems, installation and r Water Softner or Iron Filter? Sep 21, 2015
Water Softener Forum, problems, installation and r Pre filter before water softner and a few more questions May 19, 2013
Water Softener Forum, problems, installation and r retrofit a water softner to become an iron filter Aug 30, 2011
Water Softener Forum, problems, installation and r New softner, tank and filter question. Aug 2, 2011
Water Softener Forum, problems, installation and r water softner filters: Can you interchange? Aug 29, 2010
