Softener backflow question?
Discussion in 'Water Softener Forum, Questions and Answers' started by chargedmr2, Aug 15, 2010.
  1. chargedmr2
    chargedmr2 New Member
    Jul 22, 2010
    TX
    Quick question about they way I plumbed my softener:
    The main line that feeds the softener tees off to an outside water faucet (just a few feet before reaching the softener) so that I don't get softened water through my outdoor hose. When I run the hose, the meter on the water softener indicates flow for about the first 5 or 6 seconds of the hose running and a couple of seconds when I turn it off. This seems to indicate that some of the pressure in the media tank escapes back through the valve and down the feed line when the hose is turned on as things equalize. Do I need a check valve on the main line just after it tees off to the hose to prevent this? Or is this no big deal?
    Thanks for your help.
  2. jadnashua
    Are you on a well? Depending on the pressure differentials, I could envision some backflow. Now, not sure if that would be a problem with the softener. With a well system, additional checkvalves tend to create other problems.
  4. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    Since both the sillcock and the softener are on the "potable" water system, no you don't need a BFP or a check valve.
  5. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Is there any iron in the water?
    If there is water flowing backwards through the softener, there might be some challenges as the backward flow is unpacking the resin bed and then when the water flows the correct way there could be some untreated water getting through...
    So if you have had this going on for some time and have not seen any problems......... let it be, but if you have seen some challenges from time to time then you may wish to put in some kind of backflow/check valve between hose and softener so that does not happen.
  6. chargedmr2
    Jul 22, 2010
    TX
    Thanks for the replies. We are on city water so there is no iron to worry about. I don't want hard water leaking through so maybe I will consider a check valve. As is, however, we only use the hose infrequently so this won't be a common problem.
  7. big dripper
    big dripper New Member
    Aug 12, 2010
    Sorry, I misread the original post and thought you were talking about a backwashing system.
    Whenever you replace the housing---only---hand tighten it. Many make the mistake and apply the wrench and bind it down tightly, but have a tremendous time getting it off.
  8. jadnashua
    If you DO install a checkvalve, keep in mind that that will make the system a 'closed' system and you will have to install an expansion tank ,if one doesn't already exist. if you don't, when the water heater gets emptied and needs to heat a fair amount of water, when it expands, it will pop the T&P valve, and you'll have water on the floor. The expansion tank can go anywhere on the cold side before the WH, and should be after any shutoff to it so it can't be isolated inadvertently.
Similar Threads: Softener backflow
Water Softener Forum, Questions and Answers Advice for replacing a water softener for iron removal Sunday at 12:24 PM
Water Softener Forum, Questions and Answers I need a professional’s guidance in replacing my water softener. Feb 13, 2017
Water Softener Forum, Questions and Answers Softener resets and reloads about every three days Feb 11, 2017
Water Softener Forum, Questions and Answers Softener, Just need some advice and help... Feb 9, 2017
Water Softener Forum, Questions and Answers Water softener size Feb 9, 2017
