soft water to toilet
Discussion in 'Toilet Forum discussions' started by tjbaudio, Dec 15, 2005.
  1. tjbaudio
    tjbaudio Sound and Light Suppervisor for a School District
    Dec 6, 2005
    sound and light suppervisor for a school district
    Wisconsin
    While a friend and I were talking about hard water and softeners it came up that he does not soften the watter to his toilet. He figures it is cheaper to replace the valve every year or so than it is to flush soft water down the drain. He has very hard water. Mine is at 26 grain and I think his is worse than that! I am installing a softener soon and I am wondering if there is any reason to do the same. One other difference is he has a cheep toilet and I plan on putting in one of the TOTO brand toilets.
    Thank-you
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Any time you can soften hard water it is better on all the fixtures. Your friends toilet can get buildup on the inside where you can't see it or easily deal with it eventualy causing problems.
    Let the soft water go to your new toilet.
  4. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    toilet
    Keep it soft water to the toilet.
  5. Gary Slusser
    Retired
    That's because I correctly sized his new softener, using the Clack WS-1 control valve, that he bought in Jul '04. And he uses a bit higher salt dose than I told him to, but he has to due to using potassium chloride instead of sodium chloride. But I agree with softening all the water IN the house and a tap by/at the garage for washing vehicles etc.. If possible, all other outside faucets should be plumbed with hard water unless there is iron in the water that will cause rust staining on lawn, plants, walks etc..
    Careful with the use of KLC and plants, the manufacturer says it can cause problems. Remember you taught me that Steve.
    Gary
    Quality Water Associates
  6. bnbhoha
    bnbhoha New Member
    Jul 9, 2005
    Illinois
    I would like to measure my hard water grain. How can I do this? Thanks
  7. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    You can buy test kits at hardware stores or on the web.
    If you have city water, you can contact the treatment facility for that info.
    You can also send off a sample of your water to be tested. Sears, among other sources, will do this.
Similar Threads: soft water
Toilet Forum discussions Toto Drake and water softener Sep 30, 2016
Toilet Forum discussions Is there anything with large drain, great bowl clean, OK with softscrub, and not white? Jul 14, 2016
Toilet Forum discussions Toto Pacifica Soft Close Seat Removal Mar 7, 2016
Toilet Forum discussions Toto soft-close seat Jan 6, 2015
Toilet Forum discussions soft close seat for Toto Pacifica Mar 28, 2014
