Soffit Vents
Semon
Tennessee
I just had insulation blown in the attic space and am about to put new soffit and fascia on.
I want to put vents at the suffix end of the roof the Styrofoam ones.
Do I need to put one between each trust or every other one?
Smooky
North Carolina
roof vent baffles
Use the foam or plastic baffles between all of the rafters or trusses. Also make sure the insulation is not blocking the soffit vents so you have good air flow up to the roof and out ridge vents etc.
http://inspectapedia.com/interiors/Roof_Vent_Baffle020DFs.jpg
http://www.countryplans.com/images/gr9-insl.jpg
Dana
In the trades
Usually you'd want to put in the rafter baffles BEFORE blowing in the insulation, since putting them in after the fact is a dusty/itch PITA.
Be sure to clear the soffit vent holes completely, and backfill the insulation evenly or you'll get cold spots (sometimes even condensation on very cold days) on the edge of the ceiling in winter.
