So much for a "Professional"
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Rngr275, Sep 24, 2012.
  1. Rngr275
    Rngr275 New Member
    Mar 26, 2012
    Upstate NY
    Little pissed but but here goes....
    Hired a plumber to install DWV for a bathroom/laundry room combonation. I was going to do it but wanted to make sure it was done correctly. I read the Tips link provided here and had a good feel for what needed to be done so that I could check his work (came reccomended) and I got a couple references. Over all the system looks good and is pretty close to what I would have done, except for one thing: 3" main drain line , shower feeds in with 3-2 Wy, same for washer, toilet feeds the 3 in from 3x3 wy w/clean out and the last fitting in the line which comes from the bathroom vanity he used a sana tee. I have read enough to know that you are not supposed to use a sana tee in a horizontal position. "Number 1 plumbing error"
    I confronted him and his answer was that use a 3x2 wy would put the fitting to far down the drain and since it was for a vanity there should be no problem. I told him that if it fails inspection it will be changed but I am wondering what happens if the inspector doesn't catch it. Can it cause problems and should I have him correct it. Can toilet drain "Stuff" catch? It is positioned correctly just not the fitting I was expecting?
    Little mifed I even have to ask here?:mad:
  2. hj
    It is a "theoretical issue", related to giving the sewage a "boost" on its way downstream. There are probably thousands of DIY and handyman installations like that which have absolutely no problems. It should not pass inspection however. IF he only knew how to use a Y, and not a combo, then his abilities are suspect, however. I use LOTS of combos, but few Ys.
  4. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Nobody uses combo's here. Can't get them without having to special order them. We use a wye and an 1/8 bend.
    He could have also used a wye on it's side, to a long turn 90 to save some vertical space.
  5. Terry
    Aug 17, 2004
    Like hj, I use a lot of combos.
    They take up less space. Dropping a lav into a 3" horizontal is going to work, but the combo would have been nice.
  6. Tom Sawyer
    Nov 29, 2010
    Maine
    I wish we could get them here. The only place I have ever seen a PVC combo is at Lowe's
  7. hj
    quote; Nobody uses combo's here
    Where do you buy your supplies? At an Ace Hardware store? ONe reason I would use a Y is to connect it to a 1/6 bend to make rolling and rising 90 degree connection.
Similar Threads: much Professional
Plumbing Forum, Professional & DIY Advice How much to tighten this connection? Saturday at 11:48 AM
Plumbing Forum, Professional & DIY Advice I apologize if I imposed too much with "Help with rough of new ICF/SIP house in MI" post Apr 18, 2017
Plumbing Forum, Professional & DIY Advice Venting Saniflo. Much confusion Mar 15, 2017
Plumbing Forum, Professional & DIY Advice Help - how much stub needed for new shut-off valve? Mar 3, 2017
Plumbing Forum, Professional & DIY Advice How much pressure can 2" DWV pipe take? Is it okay to use in pool plumbing? Jan 8, 2017
