Snaking trailer plumbing
Discussion in 'Drain Cleaning' started by Mad Plumber, Aug 30, 2008.
  1. Mad Plumber
    Mad Plumber Mad Skills
    Aug 13, 2005
    Plumming
    What do I do about trailor plumbing. I put a snake down 25 feet by hand did not undo the clog. I tried one of those hose water ones to clear the clog. but the clog or pipe stops about 5 feet down. are the pipes under the trailor horizontal is that why the hose one doesnt work. what should I do.
    Ann W.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I would call a pro!
    I'm guessing that the drain is the kitchen sink line and it would run back to the bathroom area in the center to the rear of the trailer. 25' is not long enough. A pro will have a snake that is long enough to do the job.
  4. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Not only is the length an issue, but over time the kitchen drain lines in a trailer have a tendency to sag and even if you un clog it this time it will just return. Someone will need to crawl under there and re hang it.
  5. Redwood
    Dec 15, 2007
    Service Plumber
    They are no doubt a miserable drain to clear. A long flat run with almost no pitch and a high likelyhood of the sag that NH Master spoke of...
  6. hj
    drain
    Very often the internal drain lines run above the floor under bench seats.
  7. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Very very often Cats have used the underside of the trailer as one gigantic litter box :D
  8. Redwood
    Dec 15, 2007
    Service Plumber
    Or find this guy has made a home...
    [​IMG]
  9. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Or worse yet...
    [​IMG]
  10. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    All of the previous answers to your question are valid, but I'd add one more to the list. In my opinion, it would be money well spent to call a professional who has the size auger to really clear the line. Hand-held snakes are too small and not very effective on many clogs. DIY plumbers who have come to this forum for similar advise are frequently warned of the dangers involved of trying to use a professionally-sized auger as well as the futility of using chemicals. There are times to DIY, and times to call in the pros. This is one for the pros.
Similar Threads: Snaking trailer
Drain Cleaning Advice for maybe snaking a septic tank or d-box... Dec 17, 2012
Drain Cleaning bathroom sink clogged after snaking with black sludge Sep 11, 2007
