Smooth sink handle removal
transporterjr
I have a 2-handle kitchen sink faucet, Grohe, installed 14 years ago. it is leaking slightly and I thought I would pull the valve to see if I can match faucet washer (if it has them).
My problem is that the handles are smooth chrome and there are no screws anywhere, not even a little set screw at the handle base. There is a line between the base of handle and an identical diameter cylinder extending into the faucet which makes it looks possible that these handles were screwed on.:confused: However, I cannot unscrew them (clockwise or counter-clockwise) and I am afraid to use too much force, unless I know this is the right approach.
Any ideas? And will I be able to get any parts without any modle number?
John
Frenchie
Jack of all trades
John
This is one of those situations where a Picture's worth a thousand words.
Is there a cap that you can pry up anywhere?
transporterjr
No, there's no cap. You are right about the picture, I'll try and take a picture tonight and post it then.
John
Cass
If there is no place where a set screw is hidden then it will / should twist apart...it should have been put together with some silicone grease when installed but I am almost sure it wasn't because very few plumbers install them with taking it apart 14 years later in mind which is to bad for every one...
transporterjr
Here is the picture of the faucet, you can just see the "ring" going around the base of the handle IMG_1704.JPG
