Smelly furnance
Discussion in 'HVAC Heating & Cooling' started by Ian Gills, Feb 8, 2008.
  1. Ian Gills
    Jul 24, 2007
    I have a slight problem with the hot air my furnace blows. Every now and again it smells, just like the "burnt, dusty smell" many of you may get briefly when you first turn your furnance on after a long period of non-use.
    It is not CO. I have three alarms in my house, and a fourth with a digitial display that keeps showing zero.
    But the smell, while it comes and goes, is worrying my wife.
    What do you think it can be?
    I had the furnace serviced last year and cleaned.
    Could it just be that I need a new filter (although I do replace these regularly as well)?
  2. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    Your duct work could be full of dust and dust bunnies that would give you the same effect.
    Vacuuming you duct work would probably eliminate most of the odour. You may be able to vacuum out the return air as well. You will need to get access by cutting a square from the sheet metal. Cover the hole with a bigger peice of metal , a few screws and aluminium metal tape
Similar Threads: Smelly furnance
HVAC Heating & Cooling Smelly heating vents Oct 6, 2010
HVAC Heating & Cooling update furnance / AC with better efficiency heat pump? Aug 25, 2013
HVAC Heating & Cooling keep haveing to hand start oil furnance Dec 11, 2009
HVAC Heating & Cooling Furnance Oct 19, 2008
