Smelly Basement Drain
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lbeattie820, Sep 27, 2005.
  1. lbeattie820
    lbeattie820 New Member
    Sep 27, 2005
    I read a post earlier about this, my problem is similar, but different...
    1. 40 year old house
    2. Smelly basement drain
    3. Does not smell for 3-4 days after pouring water down the drain
    4. The drain holds water
    5. No flies breeding in or around the house.
    6. The drain is packet tight in cement and the water flows easily through it.
    7. We live in town, no septic tank.
    8. We had a water heater blow up about 5 years ago, could the sludge from that cause the smell? We have lived there about 12 years and I don't remember a smelly drain until the last few years...
    please help.... :(
  2. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    Probably stagnant water sitting there getting bad. Maybe new water displaces some of the bad water or dilutes it enough.
    This can be indication of drain problems, but not necessarily no drain problem w/o them.
    I thought the drain held water? If water is flowing through it and its smelling perhaps there is no trap in the drain.
    I would say from your comments most likely its plugged up or at least partially. If everything else in the house is functioning just fine, then its probably in the trap and can pull it out with a snake/auger. Plunging MAY push it furthur down and cause problems else where.
    Unprofessional Opinion.
Similar Threads: Smelly Basement
Plumbing Forum, Professional & DIY Advice Smelly basement drain Oct 24, 2004
Plumbing Forum, Professional & DIY Advice Smelly hot water even after new anode rod Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Problem with smelly sinks Jul 9, 2016
Plumbing Forum, Professional & DIY Advice smelly toilet bowl even after replacement! Jun 26, 2013
Plumbing Forum, Professional & DIY Advice Smelly Kitchen Drain Nov 20, 2010
